Build Advice Help putting this PC together and will it work ?
Elliah246
157
5
585
I'm asking for a friend who's asking for a friend who's asking for a friend, crazy i know. But here i am.
Specs are as follows:
CPU • AMD Ryzen 7 9800X3D
GPU • AMD Radeon RX 7900 XTX
Board • ASUS ROG Strix X870E-E or ASUS ROG Strix B850-E
Can't make up my mind which board to take, would be so nice if you can help me out... pros/cons? The most expensive option isn't always the best.
PSU • BE QUIET! Dark Power Pro 13 1300W
I've read bad reviews about this power supply like explosions or disturbing noise, however the previous series (pro 12) sold out. Any titanium 80 plus alternatives?
Will 1000W be fine for this system?
Display • ASUS ROG Swift OLED PG27UCDM
This monitor is 4k, 240Hz and uses Displayport 2.0, can the AMD Radeon RX 7900 XTX graphics card even handle the UHBR 80 spec or should i wait for the next gen?
I want to avoid DSC.
Case • Corsair 4000D Airflow ATX Mid Tower
CPU Cooler • Arctic Liquid Freezer III 360
Keyboard • Any non RGB with fast responsetimes
Help me find one?
Mouse • Logitech G502 HERO
Memory/Ram • dual channel DDR5 2x16 GB or 2x32 GB
On AMD's website i couldn't find EXPO certified ram from corsair, is there any corsair ram that will work out well as dual memory channel with expo enabled?
Otherwise which brands can you recommend? From my understanding the ram should have a low CL number (low latency) and high MT/HZ.
What's the best DDR5 options with lowest CL combined with highest HZ? For example my current corsair vengeance runs at C16 combined with 3200MHz.
I can't find anything near C16 when it comes to DDR5. Your help is greatly appreciated.
I mentioned the 5090 as an example since it's by far the most power hungry card on the market. But who knows how it's going to be in 2 years.
It doesn't really matter what kind of games you expect to play. Your PSU has to provide enough power for your system to work at 100% load, otherwise you would have a lot problems. The 7900xtx is not as power hungry as the 4090, for example, but still requires a good amount of juice. 850W should be fine if you don't get an OC version, but some people say it's better to go with 1000W to have some extra headroom. But if you get an OC version (with 3x 8-pin connectors instead 2x), then you should definitely go with 1000W.
Thanks again for helping me!
I was going to get the unlocked version with no plans to use the OC but eventually trying it out.
OC hardware has more resell value.
Since you mentioned 3x8 ping connectors instead of 2, i didn't even consider this... does this affect my PSU choice? Are ATX 3.0 or 3.1 PSUs compatible with 3x8 or do i have to look out for specific models only?
If I understood well, the only difference between 3.0 and 3.1 is the new improved (and safer) version of the 12VHPWR connector (the 12v-2x6). You are not going to use either of these with the 7900xtx, but again, if you want to be future proof go with 3.1.
Edit: just make sure the PSU has at least 3x PCI-E 8pin or PCI-E 6+2. For example, this one has 6 of them:
https://www.newegg.com/corsair-rmx-...17-139-334&cm_sp=product-_-from-price-options
X870E
CPU PCIe Lanes:
16x 5.0 (GPU)
4x 5.0 (M.2)
4x 5.0
Chipset PCIe Lanes: 20x 4.0
Could anybody explain this?
When looking at the board manual, where can i see the PCIe lanes?
I knew that the GPU uses PCIe as the connection method to the mainboard, but what do they mean by chipset pcie lanes and cpu pcie lanes?
The info comes from here:
The AMD B850 uses PCIe 4.0 for gpu graphics, buying a gpu that supports PCIe 5.0 will still be compatible from what i've read, is that correct? There should only be a very very minor performance throttle, 2-4% from what i saw. Is that true?
Why do mainboards with 2x PCIe x16 not exist?
The specs page of the B850E officially supports only Windows11, however chances are windows 10 or linux will run aswell?
So as i said specs page of the B850E supports win11, nothing more.
Does it make sense to worry if win10 will be functional or can we expect it will most likely work out just fine? Just because an OS isn't officially supported doesn't mean it won't work, but how high is the risk? Should i hold back on buying this board if i intend to install win10 ?
I can't see why it wouldn't work with Windows 10. Windows 10 will go EOL later this year so it seems like a bad idea to install it now.
Yeah, I can't see a logical reason to stick with Windows 10. If you don't want the full up Windows 11, look into alternatives like Tiny 11 and other modified Windows installations.
As for your questions regarding PCIe lanes:
The CPU has a fixed number of PCIe lanes. This is used to connect to everything, including the chipset. What a chipset effectively does is allow you to connect more things to your system then you have total lanes for. The idea being that you aren't using all of the bandwidth at the same time, so while your sound chipset used a 1x PCIe connection to the chipset, it doesn't use anywhere near that much bandwidth. So other things can share that data pipeline to the CPU.
One example would be hitting the system's limits with storage. If the CPU has a 4x or 8x PCIe lane connection to the chipset (I can't actually recall on AM5, and I am too lazy to look it up right now) And you install 3 or more 4x NVMe drives to the chipset, no big deal. But if you wanted to get maximum speed from 3 or more at the same time you would be limited by the CPU. B650E and X870E, the E boards, actually take this a step further. There are two chipsets connected to each other on the same serial bus to the CPU. So you can plug in a lot more things, but are still limited by the bandwidth available to the CPU at any given moment.
There are boards with more direct CPU PCIe lanes, but also different CPUs. Threadripper can have multiple x16 slots. These boards and CPUs are quite a bit more expensive as a result.
my reasons to go with w11 instead of 11 are simple... windows 11 is by definition malware, it steals an insane amount of personal information, it has zero respect for the user. i wont use malware as my os. windows 11 makes over 400 connections during first install, it is entirely insane.
how does this setup impact my systemperformance when we take the specs i listed in first post as the system,
2 nvme m.2 drives, one gpu, one sound card
It doesn't. You just have to be aware that the listed specifications aren't always going to achieve maximum performance under all circumstances. Performance listed by manufacturer's are done with the best possible conditions to showcase their products.
Every system is a little different, as is each component, they are manufactured to tolerances, not exactly. If you benchmarked this system and another one built with identical parts, it would have different results.
Even third party reviews have to be taken with some skepticism. Even when they are very detailed about testing parameters, there is the possibility they leave something out. And many use open test benches, which skews performance results.
