Help! Q6600 upgrade for gaming?
Paintrain84
63
Okay, so i haven't posted much on this forum but lately i haven't been able to get the whole "I WANNA UPGRADE" out of my head! About 3 years ago i made my first real gaming computer and it went great. In-fact, i still have it and it runs well to this day. I just purchased a lap top about 2 months ago, and did a bit of research before i did, i wanted a sweet gaming laptop for the best price "Like we all do".
Well, i settled for the N61JQ ASUS that has the i7 (lower end 1.73ghz) and the ATI HD5730. Well it seems to be more of a nice multimedia laptop than anything, not quite living up to the FPS i crave! So i thought "Okay, maybe ill go ahead and upgrade the ol PC".
The case is awesome, i have the Thermaltake Armor+ full tower which still sells to this day for 200 bones.
The power supply is a beast at 750W so no shortage there
Monitor is sick, i just upgraded and HD etc. is good as well
What i am running is an Intel Core 2 Q6600 Quad Core. when the strong quads came out, this was the lower end model but was still such a solid CPU at the time i thought sure why not save some money and still get a nice cpu, well as it turns out with all this i3, i5, i7 3+ghz with hyperthreading and sandy bridge such and such, it has completely confused me! I am also running a P5ND SLI Motherboard with 2x SLI 9800 GT's (Fail, what a waste of money that was, those cards are terrible, and i def need to upgrade!). I am also working with 4gb of RAM but forget off the top of my head what it is.
So my question is, What processor / Mobo / Graphics card should i bother upgrading to!? I have heard so many mixed reviews, please someone tell me what these new processors have over mine and why i should upgrade the one i have. I can run games and what not at a moderate level but at ultra or high settings....well even WoW slows down a little, so i want something smooth and impressive without spending 800 bucks.
I NEED EDUCATION! :) Thanks guys and gals!
Paintrain84
63
Hey king, is there a sort of "Standard" for "Safe overclocking voltage" or do you suggest i stop wasting your time and just go research the whole thing from the noob guide and up? :)
Don't do liquid unless you want a really really really high OC.
3.0Ghz should be safe. Also, there are safe voltages, but it depends on the CPU. The Intel website might tell you like AMD does. I'll check, one sec.
Ah your not wasting my time
I am not an expert at overclocking CPUs
I am an "expert amateur"
I do know that you can get decent overclocks WITHOUT
upping voltage especially on Core2s
for your reading pleasure and specifically talks about q6600
http://www.overclock.net/intel-cpus/497993-newbie-guide-overclocking-updated-core-2-a.html
i havent really OCd a rig since the Athlon XP days LOL
so I have to read that guide thoroughly myself to catch up
but the basics are the same
really if you can get a decent overclock without overvolting
especially on air then the extra mhz you gain from overvolting
will not be a big enough performance difference to make
it worthwhile
If you have a ten fan windtunnel or liquid cooling then
that is where overvolting comes into play
If you knwo what you are doing, you can normally flash it. Sometimes, you can't though. As for your laptop, normally they can't be O.C.ed unless a you the ASUS ROG Connect by ASUS. I wouldn't recommend O.C.ing a laptop anyway though, they don't have sufficient cooling.
Paintrain84
63
Well heres the thing, I DONT KNOW WHAT IM DOING! lol!
At any rate i figured the same thing about the laptop, was just curious. Ill have to tinker around with learning how to overclock my Q6600. Im def interested.
i had to increase my voltage on my core 2 duo e6600 to get it past 2.8ghz stable, but ive heard many can get close to 3ghz with no voltage increase. you can pump a fair bit more voltage into these things safely, but just increase small steps at a time untill you find a stable setting for 3ghz. id suggest to just go 100mhz at a time. if you get to 3ghz and everything is still running stable then dont worry about the voltage. if it wont run stable, just increase the voltage small amounts at a time and test for stability. there are plenty of overclocking guides for this cpu http://www.bit-tech.net/hardware/cpus/2007/07/25/overclocking_intel_core_2_quad_q6600/2
heres a good ccomparison, using a gtx480 vid card (similar to gtx570 in performance) showing various cpu's. imagine your cpu as a phenom x4 in this articl, since performance is about spot on, clock for clock http://www.tomshardware.com/reviews/best-gaming-cpu-core-i3-2100-phenom-ii-x6-1075t,2859-10.html you can see that in most games there isnt a huge difference with various cpu's.
Paintrain84
63
well the update: It turns out the HD6950 was really the answer to all my problems! LoL! Im SO impressed with how MUCH this graphics card has improved the performance of my games, it was insane. Changed 15-20fps into 60+fps maxed out! It was amazing. I guess i underestimated the ol' Q6600 setup i have lol. The i5 would def be a great addition when im ready but this card is AMAZING and wow what a difference. Impressed.
PS: I flashed the 6950 to the 6970 and its even better, although prob not even really needed just yet, it was too easy not to do it! Just an extra tid bit of info!
