Question Help - Receiving “No Signal” on monitor with PC
Jun 28, 2025
Hi,
I am having issues currently with my PC. Upon booting the PC, I am typically able to advance to the “Enter Password/Pin” screen before I receive the “No Signal” message.
I am able to boot on Safe mode with no issue and from there have tried uninstalling my current drivers in the attempt to reinstall.
After uninstalling , I am able to boot my PC normally and reach the desktop, however after installing / updating my drivers once again, it seems to lead to the same issue and will eventually result in a “No Signal” issue.
Does anyone have any advice on what could be causing the issue? If I am able to boot in safe mode as mentioned and perform the above steps, would that mean that it may not be a hardware related issue or is that still a possibility regardless.
Included any information I could;
CPU: AMD Ryzen 5 5600X
OS: Windows 11
GPU: Nvidia 3060ti
Ram: 16gb
Motherboard: HP 8949 11
Bios: F.20
1TB SS
Monitor: LG 27UD68P - B
Note: I have clean installed windows, swapped GPU, tried multiple cables / monitor , all resulting in the same issue it seems
I appreciate any help.
Many thanks.
I am running on Windows 11
Nvidia 3060ti
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
You speak of installing drivers for your GPU, what driver version are you working with?
Nvidia 3060ti
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Hi there,
Thanks for the quick reply.
I have added as much info as I could right now to the original post.
As for the driver version, It would just be the latest Nvidia drivers.
