Help Regarding choice of system
Lancadore
Commendable
May 27, 2016
14
Hi.
I am planning to buy gaming PC for approx $690.
1st one is:
Processor: Intel i5 6400
GPU: Gigabyte GTX 950
RAM: Kingston 8GB DDR4
Motherboard: MSI H110M PRO-D
HDD: 1TB Seagate Barracuda
Power Supply: Be quiet 400W
2nd is:
Processor: Intel i5 6500
GPU: Gigabyte GTX 950 XTREME
Motherboard: Asus B150M
Power Supply: Corsair 550W
Which one should i select? And please explain why?
If you are planning to buy the PC, and it is the build-your-own.
I add the list one with gtx960, and other one with r9 380 if you don't mind use the AMD GPU.
From your two PC, the 2nd one Gigabyte GTX 950 XTREME is good but it costs too much, which has the price tag as same as the gtx960. And if you can buy it, then r9 380 is much better than either gtx950 or gtx960 in that price range.
For PSU, Be quiet 400W is fine for gtx950, but the 2nd PC, it depends on which model 550W, but if you are in USA, the xfx TS 650W gold is much better.
For the RAM, the price is very low, recommend to buy the 2X8 GB set. And I add the z170 because the higher speed RAM will boot the performance little bit, and either b150 or H110 MB can support the...
For the RAM, the price is very low, recommend to buy the 2X8 GB set. And I add the z170 because the higher speed RAM will boot the performance little bit, and either b150 or H110 MB can support the 2133mhz RAM only.
PC with gtx960
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($194.99 @ SuperBiiz)
Motherboard: ASRock ASRock Z170M Pro4S Micro ATX LGA1151 Motherboard ($82.98 @ Newegg)
Memory: G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4-2400 Memory ($52.99 @ Newegg)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive ($49.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card ($163.98 @ Newegg)
Case: Zalman Z3 Plus ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply ($44.99 @ Newegg)
Total: $671.80
Generated by PCPartPicker 2016-05-28 13:15 EDT-0400
PC with r9 380
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card ($159.99 @ Newegg)
Total: $668.41
Note: I assume you have the OS so that I don't add the OS.
Sir you are the boss. Thank you very much
