Help- Samsung Pro Evo 1TB data corruption?
ver2ual
Commendable
Nov 30, 2016
I have 2 Samsung Evo Pro 1 TB SSD that I am using for backup storage. A few weeks ago I got the common error "Disk Needs Formatting". I tried to recover the data and then formatted it. This week I'm using the other SSD and suddenly could not open the the folder and kept getting a corrupt error. I dismounted the SSD, and plugges it back in. Now the I get the "Disk Needs Formatting" error and can't access my data.
My question: Are SSD's typically this unstable and more sensitive to data corruption than HDD's? These drives were incredibly expensive and are totally unreliable.
That is odd.
So you are using a dock to swap these drives in and out? That could very well be the issue. I would try to do the Safely Remove Drive option vs just yanking it out if that is what you are doing
SSD's are just as easily to corrupt on a "Software" level as HDD's because it has nothing to do with the device it self but what the OS write to it.
But I would run Crystal Disk Info. Just to see if they might be failing but SSD's should have a MUCH longer life span than HDDs.
Ok. Thaanks for that. I've never had a normal external HDD give me the error- ever, and I've had 2 SSDs in the last month. Could it be becasue of the Sata bay I am using to mount the drives?
Something new has happened that I can't explain. Now with the drice dismounted and the computer rebooted, my DVD drive is showing it allocated as the Samsung SSD- and the DVD drive is empty. See image below:
