I just purchased this SSD about a week ago and I discovered that its performing very poorly due to running the performance benchmark test using the samsung magician tool. I have looked around and haven't found an answer I am looking for or anything that would suggest why its running slow.
Yes TRIM IS enabled.
Yes I am hooked to the correct SATA 3 port on the mobo and AHCI is enabled in BIOS from the get.
Yes I have Rapid Mode enabled and the OS optimization is set for maximum performance.
I am only using 158GB of 931GB. Any suggestions would be very helpful! I will post a screenshot below of my benchmarks.
