terry4536 :
No you can't substitute a PCIx1 for a PCI Express x16. They are very different. For example the PCI Express x16 slot provides 300 watts to the graphics card. That is the only slot to do that.
Just to note, the PCIe x16 slot provides a maximum of only 75 watts, not 300. This is why the 60 watt GTX 750ti is so often mentioned in the "
Best Graphics Cards for the Money" article here, as it's the highest performing card that
doesn't require a supplementary power connector; any card needing more than 75 watts will need additional PCIe power cable(s) from the PSU.
Also, while I'm here, it is
technically possible to use an x16 PCIe device, such as a graphics card, in an x1 slot, either via an adapter, like
this, or in an x1 slot that is open ended (as some smaller slots, particularly x4 slots, occasionally are). The gaming performance would be extremely hamstrung due to the low slot bandwidth, so I certainly don't suggest anyone do it for that purpose, but it is
technically possible, and is/was often done by cryptocurrancy miners so they could run
6 cards on a single motherboard (the bandwidth isn't really an issue for that particular task).
Sorry, feeling a bit pedantic today
