Question help to enable AHCI
chouiyekh
Commendable
Nov 20, 2017
67
hey guys,
i have a workstation Z210 running windows 10, i want to enable AHCI, and i need your help
here are some pictures to see that the AHCI not enabled
and
but when i access the bios to make the change i find it already set to RAID + AHCI
and if i change it i find only IDE Mode and RAID + AHCI
so please help me to enable AHCI, thank you
It's Raid + Ahci. AHCI is just a subset of the Raid driver;.
Your OS may not boot if this was not the original setting. At least you know how to change it back if it doesn't.
Let us know if you need help switching the OS to using AHCI if it doesn't boot.
but the problem is that i can't change it only to AHCI on bios as you see in the pictures i attached there are only two options (RAID+AHCI) and (IDE), it's already set on RAID+AHCI and the computer boot without problem, but the AHCI not enabled because Samsung Magician said AHCI Mode Deactivated, and the same thing on device manager ( see the picture above)
