help to understand 3DMARK bench
PC-GAMER_1
Commendable
Feb 3, 2017
23
Hi all,
I am kind of new to the 3DMARK bench mark and was wondering if anybody could help understand if the tests I ran while overclocking with a stable system is actually good compared to others. I did compare online and it did say i was 92% better than other results but I am just being fussy and want to make sure i am getting the most out of my new card and system.
not sure if this will work ...
http://
http://
I only seem to hit 60-68c also
thanks in advance all
James
''Yes sorry was meant to have said I've seen other people's results come back at the 12000+ results that's what I'm confused over ''
well you got to look at if there sli results and that's what I see for them over 12000+
then you got to conceder any overclocking they used on there CPU seeing you dealing with ''K'' processors and then how they got there cards overclocked
I can run my card up to do a great run of firestrike to get a ''bragging'' score
look here and see theres a thing to select the amount of GPU's used use the Quick filters - ''Number of GPUs '' - 1 or just scroll down the list till you see the single card scores [for me the first single card score was score result number 4951 and it was a...
look here and see theres a thing to select the amount of GPU's used use the Quick filters - ''Number of GPUs '' - 1 or just scroll down the list till you see the single card scores [for me the first single card score was score result number 4951 and it was a score of 8376
http://www.3dmark.com/search#/?mode=advanced&url=/proxycon/ajax/search/cpugpu/spy/P/2005/1085/13502?minScore=0&cpuName=Intel Core i7-6700K&gpuName=NVIDIA GeForce GTX 1080
so with that your score is nice and for sure could be a lot worse
