I understand how a four pin fan with PWM is controlled, but I'm confused on how 3 pin fans are controlled in practice.
So lets say you have an AeroCool DS120 (http://www.aerocool.us/accessory/images/dsfan_12blue.html) that runs at 12V normally, or 7V with the inline adapter. If the fan is set to 12V, and a fan controller wants to turn it down, does it drop to 7V immediately or can it go to 11V, 9V, 8.5V etc? How does the controller know to raise the power if the fan stops spinning and how low can the controller take the fan (Down to 7V? 5V?). What happens if the 7V adapter is then used?
I know this sounds like a textbook question, but I'm just confused and want to understand
