HELP! Unigine Valley and Heaven error
Try uninstalling Heaven and Valley, running both CCleaner and Auslogics Registry Cleaner, re-booting, and download a fresh copy and reinstall.
http://www.auslogics.com/en/software/registry-cleaner/
All I can make out from the error msg. is a trail of what the the program was doing when it halted. You could try disabling any extra stuff you have running with Windows, and try again. Do you have a bunch of apps in your tray?
Using a gtx 970 w/ latest drivers. I have already used ccleaner.
you bet i have 😛 More than 30
I'll be doing a reinstall of windows 8.1 now, hope it works after that.
