[SOLVED] HELP!! Upgrade GPU or Monitor first??
Nov 23, 2019
My current setup-
Cpu: Intel Core i7 7700
Mobo: Asus B250M-K Prime
Casing: Cooler Master K380
Hdd: Toshiba 1Tb
Ram: Gskill 8Gb 2400Mhz
Psu: Cm lite 500W
Gpu: leadtek Gtx 1060 3Gb
Monitor: Samsung SyncMaster 2233
Cpu Cooler: Cm Hyper 212 Led Turbo
Now i want to upgrade either monitor or gpu. But im confused. Help me out. (Monitor is super old)
Monitor choice: LG 32ML600M 32" IPS Full HD HDR 75Hz Gaming Monitor or Msi Optix MAG241C 23.6 Inch FHD Curved LED Gaming Monitor With 144Hz Refresh Rate.
Gpu choice: GALAX GeForce RTX 2060 Super.
These are available in my region.
Thanks in advance.
You say that your monitor is super old, if you mean with that, you seem to not see colors properly, or if you feel that you have a big input lag, i would go with the monitor first. Especially since you're having a GTX 1060 already, which is not a good card, but it's ok.
