[SOLVED] Help: upgraded CPU, now monitor says no signal
chitown35
18
Hi, I'm in a pickle here. I just upgraded my CPU from an i3-7100 to a i5-6600k.
Upon turning it on after the upgrade, my monitor says "no signal." All the fans are running fine and the red light on my M2 SSD is on.
I have no idea how to troubleshoot this. I would greatly appreciate any help.
`PCPartPicker Part List
CPU | [Intel Core i5-6600K 3.5 GHz Quad-Core Processor]
Motherboard | [ASRock B250M Pro4 Micro ATX LGA1151 Motherboard]
Memory | [G.Skill Ripjaws V Series 8 GB (2 x 4 GB) DDR4-2400 CL15 Memory]
Storage | [PNY CS1311 120 GB 2.5" Solid State Drive]
Storage | [Crucial MX500 250 GB M.2-2280 Solid State Drive]
Video Card | [Gigabyte GeForce GTX 1050 Ti 4 GB Windforce OC Video Card]
Case | [Cooler Master N200 MicroATX Mini Tower Case]
Power Supply | [SeaSonic S12II 520 W 80+ Bronze Certified ATX Power Supply]
Does your motherboard have any POST indicator (e.g. LEDs that show POST status). That could be a good place to start. Also, you could bench the motherboard with everything except motherboard, PSU, CPU, and ram disconnected to start troubleshooting it. If it doesn't boot with that configuration, the likely problem is one of above components.
