Current specs:
GIGABYTE GA-970-Gaming AM3+ AMD 970 SATA 6Gb/s USB 3.1 USB 3.0 ATX AMD Motherboard
ASUS Radeon R9 Fury X DirectX 12 R9FURYX-4G 4GB 4096-Bit HBM PCI Express 3.0 HDCP Ready CrossFireX Support Video Card
Rosewill ARC-750 ARC Series 750W 80 PLUS Bronze Certified Single +12V Rail Intel 4th Gen CPU SLI and CrossFire Ready Power Supply
CORSAIR Vengeance Pro 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model CMY16GX3M2A2400C11R
WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition Processor
I'd prefer not to change motherboards, but from what I've read the motherboard I'm currently using doesn't run well, and only goes with amd processors. I'm looking for an intel processor and motherboard that is compatible with my other specs. I'd also like to run the game CS:GO at around 300 fps, if that helps.
