Help upgrading my current system with minimal spending.
ArieHon
21
Hi, I would like to upgrade my current system to play more modern games but need advice and guidance on how to go about doing so.
Current System:
  • CPU: AMD HDZ965FBGMBOX Phenom II X4 965 - 3.4 Ghz Black Edition
    MOBO: ASRock 960GM-GS3 FX Motherboard
    RAM: 4GB G.Skill DDR3 PC3-12800 1600MHz
    GPU: Gigabyte 1GB 7770
    PSU: Corsair Builder Series CXM 500W Modular 80 PLUS Bronze
Parts I thought of upgrading:
Getting a Cooler Master Hyper 212 EVO (120mm) for my CPU to overclock.
Adding an extra 4GB of RAM, not sure if I need the same ones or just any 1600MHZ DDR3 stick.
And upgrading my current GPU to 770, 280x or 960. Not sure if my current PSU with me OC'ing my CPU can handle a 280x or a 770 (getting a used 770 from amazon since it fits my budget).
And is slapping an extra HDD plausible without me having to reinstall windows?
Any advice, are greatly appreciated.
Thanks.
-16GB with your proposition is definitely possible, Just keep the model number handy.
-Adding the TDP of the 770+x4+HDD's you come to this 200+125+10=335/12 = 28A on the 12v+ rail, PSU has 38.
Should be enough to OC the processor a good amount.
EDIT: Wrong ampage written down.
Glad to help :)
I know r9 270x is slower than the 3 gpu's you stated . But if you use r9 270x instead of hd 7770 , then it would be great and the rest of the money which will be saved can be used to buy another stick of 4gb ram
Latest posts
