Hello all!
I currently have a laptop equipped with 8GB of RAM. I want to get myself another 8GB stick of RAM because I'm tired of GTA V and Skype leaving me with less than a gig of free RAM. To do this, I need to figure out the exact specifications of my current RAM stick so I can buy one like it and run it in dual channel mode.
This is what I know about my current 8GB stick:
Manufacturer: Kingston
Type: DDR3
Speed: 1600 MHz
CAS Latency: 11
Part ID: MSI16D3LS1KFG/86
Here's a picture of it in my PC:
I do not know the RAM voltage, which is the most important piece of information. I need to know whether it's 1.35V or 1.5V. I've tried using CPU-Z, and got the following information:
However, I've been told the four voltage values (for me, where it says 1.35V) isn't always right? Is that correct?
I've also tried using Everest and Speedfan, neither give me what I need. I have noticed, as you can see in the picture of the RAM stick I attached, there is something on the plastic where the RAM goes that says "1.5V BTM". I don't know what it means, thought I'd mention it.
So, what voltage is my RAM? I can give more information if you need it. Thanks guys!
Type: DDR3
Speed: 1600 MHz
CAS Latency: 11
