Help! When removing malware Chrome seems to readd it
sezze
33
SOLUTION OVER HERE, IF YOU ARE ALSO HAVING THIS ISSUE: https://www.reddit.com/r/techsupport/comments/5xp2p5/help_when_removing_malware_chrome_seems_to_readd
TLDR; After launching Chrome it readds the malware I just removed
A bit of an accident happened recently and I got some form of malware which installed a bunch of stuff on my computer, I used several tools to get rid of it all (I followed this guide). There's one thing which I can't get removed though, it's something that is in the profiles folders for Chrome, and I've noticed through the Chrome console that it is contacting some IP in China. AdwCleaner finds 2 things in Chrome when I run it, and removes it, but when I launch Chrome again those two folders re appear, I think it's trying to sync extensions but I can't find a place to remove this within Chrome either (it's not in the extensions list). How do I get rid of it?
