Help with 1080p on gtx 960
Tom_Walker12
27
Repost from graphics crd no one knew.
So before i was using my intergrated graphics and res was at 1080p but over/under scan was being used because 1080p is not native resolution and it looked fine but got a 960 and i cannot set it to 1080p otherwise the corners go past the edge of the screen i have to use custom res and colours and everything look terrible is there anyway to fix this other than new monitor.
Using HDMI had same problem with a gtx 750 ti
veodi
17
What have you tried to actually fix this problem? Have you tried changing the resolution on your monitor via right click on the desktop?
Sorry if it sounds like a silly question but it would help if we knew what you have tried already.
Tom_Walker12
27
I have tried setting the resolution using right click, changing the colour mode in nvidia control panel, setting resolution in nvidia control panel.
EDIT :
Tried with a second monitor and seems to be fine same make different model same native res must be an issue with my monitor
Thanks
