T Tubbehh Reputable Feb 22, 2014 68 0 4,630 Feb 28, 2014 #1 When i plug it into the motherboard is it supposed to click in? i know that it locks in the with little pressure lock thingy.
Solution geofelt Feb 28, 2014 The parts are keyed to only fit one way. Check that the shape of the pins match and that the latch is on the proper side. It does take some pressure to go in all the way.
Danbuscus25 Dignified Feb 15, 2014 5,368 0 13,960 Feb 28, 2014 #2 well, push it in firmly. sometimes they will click in, sometimes not. just plug it in firmly and try it. Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,719 315 70,240 Feb 28, 2014 #3 If the lock on the cable is snapped into place then you know you're good. Upvote 0 Downvote
geofelt Titan Oct 9, 2006 54,345 4,167 174,240 Feb 28, 2014 Solution #4 The parts are keyed to only fit one way. Check that the shape of the pins match and that the latch is on the proper side. It does take some pressure to go in all the way. Upvote 0 Downvote Solution
