Help with 3rd monitor
Jannes123
18
Hello,
Yesterday i bought a new 27inch monitor, wich is working good.
So i got 3 monitors now, 2 27inches they both work good, on Dvi-d and Hdmi.
and my 3rd monitor was on a Dp port to VGA adapter, since the 3rd is old and only has got VGA.
But the max resolution was only 1600 with the DP adapter, so i just bought an DVI-D to VGA adapter, wich supports 1920x1200 resolution.
So after trying that out, the monitor is now shoing as a Digital monitor in CCC while its not.
But the problem is it shows it as a 16:9 monitor, while its 16:10 , and also its shows Lontium in the name but its a Prolite E2607 monitor.
I tried windows update and got latest CCC drivers already. Also i tried allot with the scaling and settings of CCC nothing working.
The monitor is also not showing correctly, like the left 400 pixels or so are "outside" of the monitor. i could get this correct with some settings but then the vertical is not full, like im missing 60 pixels above and down, also with the monitor options, even with horizontal position to max right, still black bars.
Please help me.
Thanks.
Oh and also, the monitorbefore was used by someone, and then it was on a Dvi-i to Vga little block connector things. and then it just worked fine. so im sure the monitor is good. also with the DP apater the screen was full.
Ok so i tried another vga cable now, the name is now showing correclty in windows display settings, but the resolution is still 1080 also in CCC still showing as a digital monitor
