Help with 4 monitor setup
Fortitude
201
I have a 4 GB graphic card (which on the box said it was powerful enough for up to 4 screens). I build my pc. start setting everything up. Then when I get to monitors, There is only one HDMI out port. I've heard that using a splitter would just show the same thing on all of the screens and I don't want that. I wanted 3 to stretch and 1 for other use. Example: game on the 3 stretch, Google on fourth monitor.
How would I do this with only 1 HDMI Out?
The memory doesn't determine how many monitors the video card supports. The 280x can support up to 6 displays with the use of a Displayport MST Hub. But where you are only using 4 monitors you don't need the hub. Now it's not going to perform well if you try to game accross those monitor though.
That's a bit disappointing. Looks like I'll be returning a few then. 🙁
