Help with a dell monitor
Snakii
I recently bought a Lenovo m91p and I put a rx 460 in it and then when it's turned on the monitor recognizes that the cables are plugged but it doesn't recognize that the pc is on. any solutions? My monitor is a s2340 dell
Make sure you're plugging into the 460, and that you have the correct/latest driver for it.
Also, make sure you are using the correct input on the monitor. So for example, if you're connecting with HDMI, make sure the monitor is displaying HDMI
