So I know there are countless posts about whether or not this pc or that pc can run Battlefield 3 and I have read many of them as well as various reviews prior to putting together this build and I would appreciate some feedback. Just to clarify before we get started I do intend to overclock the cpu and probably the ram if there is a significant gain in doing so. Also I would like to run Battlefield 3, Shogun Total War 2, Civilization V, and the like at max settings on a thirty seven inch lcd tv. My budget isn't super tight but I don't want to waste money on overkill if its not needed (see footnote). So without further ado here is the build entirely from Newegg.
i5-2500k processor
ASRock P67 Extreme4 motherboard
G.Skill Ripjaws series 2X4GB memory
EVGA SuperClocked GeForce 560 Ti video card
Samsung Spinpoint F3 1TB hard drive
Samsung Black 12X BD-ROM optical drive
Cooler Master Hyper 212 Plus 120mm cpu cooler
Antec High Current Gamer Series 750w 80 Plus bronze certified power supply
Corsair Special Edition White Graphite 600T mid tower case
Arctic Silver 5 thermal compound
If you need or want more information just ask. By the way I am open to alternatives on the case in particular. That one got great reviews but I wish it came in black like the tv, ps3, and new xbox. Also I've read that side fans are fairly ineffective. Sorry if there is any weird formatting with line breaks I'm posting from my Evo. Thanks in advance for any input.
i5-2500k processor
