Hello everyone, I have an old socket 775 Foxconn motherboard that I'm trying to troubleshoot. I think the model number is P4M9007MB, nothing fancy really, rather a side project for fun. I bought it some time ago working, but noticed that one of the SATA connectors was pulled out and only the pins remain. One day I went to turn the computer on and nothing happened. An hour or so of troubleshooting later I had achieved nothing, so I put it in storage without the CMOS battery. Yesterday, out of curiosity I decided to plug it back in to see what had happened. You see, I wasn't going to post here since I didn't really expect anything, but suddenly the motherboard booted right up! I power cycled it to ensure that everything is actually working and it posted again! I then disconnected everything to grab a keyboard and to put some thermal paste on the CPU and after that the board never posted again, even after atleast an hour of messing around.
Here are the troubleshooting steps that I have already done:
1. The breadboard test bed is just the barebones: PSU, CPU and RAM.
2. The PSU is of good quality and known working, since it was in my main computer.
3. RAM is also of good quality and known working.
4. I have two CPUs, both tested and working.
5. Everything is properly connected, I reconnected everything atleast three times.
6. Clearing of the CMOS does nothing and the jumpers are set correctly.
What I have observed so far:
1. The CPU does get warm and eventually hot, causing the board to shut down.
2. The board is responding and is able to be power cycled by shorting the front panel connector.
3. The north- and southbridge are also getting warm.
4. Connecting a keyboard and turning the computer on does not flash the keyboard lights.
5. Removing the RAM does not yield any beeps during power on.
6. Disconnecting the 4-pin CPU connector doesn't make the board beep during power on.
7. Flexing the board or the RAM makes no difference, that or I wasn't flexing it enough or on the right spots.
Any help would be gladly appreciated. I would love to eventually assemble a whole computer out of it, if it ever works again.
P.S I feel like I have to clarify this again. I would have not bothered with any of this and would have officially declared the motherboard dead, if it hadn't randomly posted fine two times. That makes me think that the problem is somewhere else and it might even be repairable.
