Help with a Multi-Rotor
RAIDKING
69
Hi Guys,
I have been exposed to the drone community and am highly intrigued in the way of filming with one. I have found a camera that by no means I can currently afford but I know the specs of it and was hoping someone knew of a Quadcopter etc. that could take this monster to the skies.
The Camera in Question: Blackmagic Designs URSA 4K PL Mount (17lbs)
This camera may and probably will eventually have a high end lens attached to it at a later date.
To sum it all up, does anyone know of a multi rotor that can drag a 20+ lbs camera into the air (exc. gimbal and the drone itself)
Thanks, RAIDKING
Edit: If it makes it any easier a RC helicopter is also a viable option.
While my experience with multi-rotors ends once you go past hobby-grade 500 size, I do have enough experience with RC helicopters to know you don't want to go that route.
I'd recommend checking out the Yuneec Q500 Typhoon or the Blade 350 QX3 AP to get started in aerial photography and filming. Anything that would be capable of lifting a 20 lb payload for an extended period of time would be massive, expensive, and largely a custom piece by piece build.
