I will place the AIO radiator in front,
And as there is intake case fan in front, The radiator will be installed with double side fans,
The intake case fan and the radiator fan on the other side,
Both will intake the air from the room inside the case.
Is this ideal ?
Here is explanation about what I mean
You can see the blue arrow is the air direction
https://ibb.co/59FS785
The photo is not mine I just edit it*
Is this ideal ?
