Question Help with B550m pro-vdh wifi
Oct 7, 2022
I've got B550m pro-vdh wifi and a 5600x. I understand that this MOBO needs a BIOS update to work with the 5600x. I've flashed the BIOS to the latest version but I'm still having issues. I'm not getting any video or USB output.
The light of the EZ-debug is OFF for the CPU (it was ON prior to BIOS update) so I'm not sure what's the issue. Everything on MOBO is running including the GPU. I've came to a halt because I don't know what do anymore. I've tried older BIOS versions, already, each time I made sure I did it right (Fat32 formatted USB, renamed file to MSI.ROM, plugged it in a 2.0. slot, made sure the red BIOS blinking light). I also removed the CMOS battery for clean install everytime. Any other suggestions? Should I just get another MOBO? If so any recommendations?
CPU: 5600x
Motherboard: b550m pro-vdh wifi
Ram: 8x2 lpx vengeance
SSD/HDD: WD blue SSD
GPU: MSI 6600 XT
PSU: EVGA Supernova 650w
Did you clear your motherboard's CMOS after you've successfully flashed the BIOS on the motherboard?
Please pass on the specs to your build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
