Question Help With Build - $1500
Hypoltan
Proper
Feb 14, 2019
230
With the current build, there are some questions I have:
Appropriate cooler for i5 9600k for decent overclock?
Appropriate motherboard to support decent overclock but not too pricey and without need for too much bling and features?
500 gb ssd that is fast but fairly cheap?
rtx 2060 or 2070 to fit the build at 1080p 144hz, want to get the best performance though still fit the budget in mind.
Case with good airflow, cable management, and is compatible that is $100 or under?
PSU 650w or 750w? Reliable psu for the wattage required?
The budget I have is $1500, though going a little over is fine by me.
This is the build that I currently have to fulfill them: Any suggestions on how to change it or make it better?
PCPartPicker part list: https://pcpartpicker.com/list/YyptfH
Price breakdown by merchant: https://pcpartpicker.com/list/YyptfH/by_merchant/
CPU: Intel - Core i5-9600K 3.7 GHz 6-Core Processor ($268.00 @ SuperBiiz)
CPU Cooler: CRYORIG - H7 49 CFM CPU Cooler ($38.00)
Motherboard: ASRock - Z390 Extreme4 ATX LGA1151 Motherboard ($139.99 @ Newegg Business)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory ($79.99 @ Newegg)
Storage: HP - EX920 512 GB M.2-2280 Solid State Drive ($76.99 @ Newegg)
Video Card: Zotac - GeForce RTX 2070 8 GB AMP Extreme Video Card ($499.99 @ B&H)
Case: Phanteks - Enthoo Pro M Tempered Glass (Black) ATX Mid Tower Case ($99.99 @ Amazon)
Power Supply: Thermaltake - Toughpower Grand RGB 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Amazon)
Monitor: Acer - GN246HL 24.0" 1920x1080 144 Hz Monitor ($199.99 @ B&H)
Total: $1492.93
Generated by PCPartPicker 2019-03-11 06:21 EDT-0400
Thank you. All help is appreciated.
maziech
Upstanding
Feb 18, 2019
354
42
240
13
The bigger, the better ;-) I'd take Dark Rock pro 4 or Noctua Nh-D15. Also, You may try with water cooling. If You wan't to OC, don't save on this part. 60$ of savings is not much, and You'll regret it later. High-end cooling will be efficient and silent.
Won't help much with that... But that AsRock seems very reasonable price/value. Should be just fine. I'd take AsRock taichi, but it's expensive, so... yeah, You'll be fine.
If You want to save some cash, I'd take 2060. 6GB of Vram should be enough for 1080p. 2070 is only about 10-15% faster than 2060.
phanteks Enthoo Pro M is a very good choice.
