Hi,
I'm new to the forum and I was hoping to run a build past you all. I've been out of PC gaming for a while, and although around 12 years ago I built my own gaming PC, I was no expert!
My hope is to order a prebuilt system from Opsys (their prices seem okay, they look like they offer a good warranty, lifetime support, free labour on upgrades and their online reviews are great).
I have a 4k monitor (Asus TUF VG289Q), so I would like a spec that can manage 4k at high settings. First game would probably be Hogwarts Legacy. The set up would only be for gaming.
I've read good things about the 7800X3D, so long as the motherboard bios is updated!
I initially started with a budget of £2k. This comes in higher at £2804, but I can stretch to that, but no further. I'd want the system to last a good 3-4 years before I consider any upgrades.
The potential build is:
Thanks so much!
ROCESSOR MODEL | AMD Ryzen 7 7800X3D (heat sink - Thermalright Peerless Assassin) |
PROCESSOR TURBO CLOCK | 5.00Ghz |
PROCESSOR CORES | 8 |
PROCESSOR THREADS | 16 |
PROCESSOR OVERCLOCKED | - |
GRAPHICS CARD MODEL | ASUS TUF Gaming GeForce RTX 4080 |
GRAPHICS CARD BOOST CLOCK | 2.54Ghz |
GRAPHICS CARD MEMORY | 16GB |
CUDA CORES | 9728 |
MOTHERBOARD MODEL | ASUS TUF GAMING B650-PLUS WIFI DDR5 |
RAM MODEL | 32GB (2x 16GB) Corsair Dominator Platinum RGB 6200MHz DDR5 |
RAM AMOUNT | 32GB |
RAM SPEED | 6200Mhz |
PRIMARY STORAGE MODEL | ADATA XPG GAMMIX S70 1TB |
PRIMARY STORAGE READ SPEED | 7400MB/s |
PRIMARY STORAGE WRITE SPEED | 5500MB/s |
ADDITIONAL STORAGE | - |
POWER SUPPLY MODEL | Corsair RM850e Gold |
POWER SUPPLY CAPACITY | 850W |
POWER SUPPLY EFFICIENCY | Gold |
WIFI MODEL | Integrated |
WIFI SPEED | Wi-Fi 6Mbps |
CASE MODEL | Corsair 4000D Airflow Black |
CASE FAN MODEL | Be Quiet! 6x Silent Wings 4 PWM High Speed Fan Kit |
CASE FANS QUANTITY | 6 |
OPERATING SYSTEM | Windows 11 Home Operating System |
Thanks so much!
