Is this PC good for gaming with 100+ fps with medium settings on most games(League of legends, CS:GO, Fortnite, Pubg), is everything all compatible and going to run smoothly, and lastly is there any cheaper alternative to some parts that would give the same performance?
Care: Cooler Master Mastergel Maker CPU-Thermal Compound Optimized for Thermal Dissipation [+10]
Case: IN WIN 101 Mid Tower High Air Flow Gaming Case w/ Tempered Glass Full Size Window [+20] (White)
CPU: AMD Ryzen 7 1700 3.0GHz [3.7GHz Turbo] Eight-Core 16MB L3 Cache 65W Processor [+50]
Case Fans: Default case fans
Fan: ENERMAX ETS-T40F-BK CPU Cooler w/ Black ENERMAX Twister PWM fans [+1]
HDD: 1TB WD Blue SATA-III 6.0Gb/s 7200 RPM HDD [+7] (Single Drive)
IUSB: Built-in USB 2.0 Ports
MEMORY: 16GB (8GBx2) DDR4/3000MHz Dual Channel Memory (ADATA XPG Z1)
MOTHERBOARD: MSI X470 GAMING PLUS AM4 ATX w/ RGB, USB 3.1, Gbt LAN, 3 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition)
OVERCLOCK: No Overclocking
POWERSUPPLY: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: EVGA GeForce® GTX 1060 Superclocked 6GB GDDR5 (Pascal)[VR Ready] [+252] (Single Card)
Price: $1154
P.S. I don't really know what overclocking is so I was just curious if I should change from having no overclocking
Price: $1154
