Help with building first PC
SimplyRex
5
So im building a gaming PC for the first time and I need some advice for all the stuff I need.
I'm looking for good performance (min. 60 fps) at medium/high settings. I found a PC build that costs like 1500€ + Monitor/Kb but Id rather not use more than 1200€ on a PC. Looking for a list of components fitting with the Thermaltake view 27 case (If the case actually matters)
1 thing I recommend is to add a 250gb ssd everything seems good otherwise.
https://pcpartpicker.com/list/Jw9GVY/by_merchant/
Cant find all the parts (Power supply and DVD writer) but I assume I can switch them for other ones in the same bracket
Can you recommend a good looking Case for 40-80€ and also Can I use the Corsair CX550 Power Supply and the Asus DRW-24D5MT with this?
