Hi guys,
so I had posted earlier asking about the AMD A-10 7850k processor for my budget gaming PC..
I decided to go ahead and buy the A-10 processor, and found this bundle deal:
A10 7850K Black Edition Boxed Processor + Gigabyte GA-F2A55M-HD2 Socket FM2 A55 mATX motherboard for $139.00.
My friend is giving me an extra pair of Crucial 16gb x 2 1066Mhz DDR3 ram that he has and I was planning on buying the Thermaltake V3 Black Edition ATX Mid Tower Computer Case too.
I was hoping to take advantage of the A-10's ability to crossfire with a 2gb R7-250 gddr5 gpu (is an Asus gpu better option than gigabyte, even if the mobo is gigabyte?) I came across R7-250x GPU's but couldn't find any information on whether they are crossfire compatible with the A10-7850k.
I was hoping you guys could tell me if
1) the 250x GPU's would crossfire with the A-10 apu? or should I look to get a R7 250 gpu instead?
2) Should I buy gpu from Asus or gigabyte, and should the brand of the mobo effect my choice?
3) Could you recommend a cheap yet decent power unit for the system (needs to be 450W I think)
4) Is the case I picked alright? or could I get something better and cheaper?
5) Do you think this system will be able to run Witcher 3 and Dragon Age Inquisition in Medium graphics?
6) Is the mobo in the bundle any good enough? and is the price point a good deal?
Thanks in advance guys! Really appreciate the help.
