help with building mini rig, and some general things
hjunajdo
Commendable
May 24, 2016
so, im building my first pc, thought i need it to be a mini rig. what cabinet will be best suited? will these components fit? would it instansly burst into 5.000.000 kelvin? so many questions, so little time
the plan is to get 16gb ddr4 ram, a gtx 1070 and an i5 6600k, with an 212 evo cooler. as a psu im thinking a cx 650, (if thats enough power?). as a motherboard im thinkink a gigabyte z170 k3. will this fit? if not, what equal components could i use instead? and what kind of "subversion"(or rather expected subversion, or is that to early to discus?) of 1070 would be best for that use?
as a cabinet, im thinking cm130 or maybe a t 380, i have also tought about corsair carbide 240 and fractal design 304. will it become to hot? will there be space for everything? what could i use instead? it should be max ca 6kg and 40*40*40cm, thought smaler would be better, if its not to mutch of a tradeoff,
in short
1) will these components fit?
2) is it enough power?
3) what kind of 1070 would fit the most?
4) will it be cold enough? not thinking overclocking here, just after hours of gaming
5) what cabinet would you take?
aaand i think thats it. for now.
ty!
edit: seems like the cx650 is to big, is fractual design integra any good instead? or what would you sugest
You need a mini-ITX form factor mobo to go into a mini-ITX case. That one doesn't fit. I recommend a better PSU. Too early to look at specific GTX 1070's. I threw a GTX 970 into this build to check for case compatibility. The Cryorig H7 is a better air cooler than the CM Hyper 212 EVO. You didn't mention an HDD, but I put one in there. Really should add an SSD as a boot drive, or if you can afford a 500gb-1TB SSD, this machine would really blaze. All of the cases you named are decent. For me, it's be between that Fractal Design and the Phanteks that I put into this build.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($233.99 @ SuperBiiz)
CPU...
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50)
Motherboard: Gigabyte GA-Z170N-Gaming 5 Mini ITX LGA1151 Motherboard ($145.99 @ SuperBiiz)
Memory: G.Skill Aegis 16GB (1 x 16GB) DDR4-2400 Memory ($54.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Video Card ($309.99 @ SuperBiiz)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case ($70.98 @ Newegg)
Power Supply: Corsair RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ Newegg)
Total: $967.92
Generated by PCPartPicker 2016-05-24 10:20 EDT-0400
with a 500gb SSD
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($149.99 @ Newegg)
Total: $1117.91
Generated by PCPartPicker 2016-05-24 10:32 EDT-0400
