hey guys , i need help on deciding where and how i should connect my 2 case fans on my Nox Hummer MC Zero Edition Case. This case comes with 2 fan switches in 3 speeds ( High , stop and Low) , and each switch controls 2 fans . i currently have my 2 fans ( one intake in the front and one exaust in the back) connected to switch #1 and the case supports 2 more ( 1 on top and 1 in the front ).
My problem is : Should i connect the 4 fans (atm i only have two but in the near future i'm getting the other 2 ) to the mobo (asus prime b350m-a) ??? is it safe to get any kind of controller and then connect mobo-> controller-> 4 fans ? and is there any way to controll the fans from the mobo and case controllers simultaniously ?
NOTE: i my case fans are 3 pin , and both motherboard fan headers are 4 pin
NOTE 2: my case only supports 120mm fans
NOTE 3: both headers on the motherboard are 4pin heads. And i have 3 pin fans
