Hello everyone,
I need some help with my case fan situation. So I ordered 4 Corsair AF120 led fans for my Phanteks P400 silent edition case. I was only using the stock phanteks fans at first (I just recently built this computer) but decided to increase my cooling capability. However when I bought the fans, I realized that I made a mistake and I did not have enough fan cables to connect all the fans.
One reason I am asking the community, is because the phanteks case has a fan speed controller button on the front of the case. Speeds going from low, medium, and high. But the cable that is plugged into it (Which I cant detach) runs a 3 header split cable; with each head having a 2 pin male end. These do plug into my corsair fans and still allow me to control the speeds. I am just unsure how the 2 pin male ends effect my connection in any way.
I was able to find two options that I am still unsure about. One is the Phanteks PWM fan hub, which is an optional edition to the case and has 6 3pin fan headers. However, I have heard that these hubs will run the fans at the highest speeds. I also found a phanteks y cable splitter which has the same 2 pin male end pins like the case.
So which one should I get? If some one has used the fan hub, will it allow me to control the speed threw the case button, or the motherboard? Would the hub handle the .4 amps that the corsair fans use? Should I look into other options?
I apologize for any confusion, because honestly I am still confused on this matter myself.
Parts
Corsair af120 led fans
Asrock z270 killer lga1151 motherboard
Seasonic g series 550w gold
Parts
