[SOLVED] Help with charging battery on I Book 4 laptop.
mayswillie
My apple IBook 4 won't charge above 74%.
I'd been getting rid of excess downloads and must have got rid of one too many.
What to do, what to do.
I'm unsure what getting rid of excess downloads has to do with it.....
The battery is completely separate, and given it's age is probably going bad. If you plan on keeping it I would recommend replacing the battery. I doubt reconditioning the battery will completely cure the problem but it will probably help a bit.
