Hi guys...this is not Austin
I have a MSI RX580 4G Armour OC edition card https://www.msi.com/Graphics-card/Radeon-RX-580-ARMOR-4G-OC
Standard specs are 1366/1750(7000Mhz) . I have overclocked it to 1450/2000( 8000Mhz) and it is nice and stable on all benchmarks/games. The only issue I am having is the heat....yes I know the RX580 runs hot. My average temps are +-70-74C when gaming on 100% fan speed which I know is not to bad. I have limited the temps to 75C on Afterburner, it never throttles back during gaming...only when running Furmark it will throttle.
My question is, how can I get this running cooler without water cooling it, if only by a couple of degrees. Mind you the card is still under warranty.
I know I have the following options :
1. Replace thermal paste - loose my warranty
2. Replace cooler with beefier one - loose warranty
3. ????
Cooling in my case is also not an issue...i have 4 intakes and 2 exhaust fans. The card is getting a decent amount of air flow over it, case is Antec P8 ( I know it is not the best case but is was cheap)
Just needs some advise or a direction to go in.
Thanks
3. ????
Thanks
