Hi,
My PC is running hot and just wondering possible problems. Newly built. All fans are the right way, Back fan is exhaust as well as top 2. 3 on the front are pulling air in. Using standard cooler that comes with the CPU. CPU in Ryzen master is auto clocking depending on power needed.
Cpu and GPU are both running 70+c while running games as an example running world war z for 1hour temps are at 70+ and case is warm. What should be the first thing to check? This was a custom built PC not assembled by me.
Haven't touched it or used ryzen master to overclock ect. Left it how it came.
Specs:
CPU: AMD Ryzen 5 2600X Six-Core Processor
GPU: Radeon RX 570 Series
MOTHERBOARD: Gigabyte a320m-h
RAM: 16gb Vengence 2666mhz 2x 8gb
STORAGE:
1x 2tb barracuda HDD
2x Gigabyte 240gb SSD
PSU: corsair 550w bronze
CASE: CiT BLaze
Specs:
STORAGE:
CASE: CiT BLaze
