Help with CPU and Motherboard Compatibility
Victor_3
52
https://pcpartpicker.com/list/skrNKZ
At my local store website I saw that this motherboard Gigabyte H110M-S2H Intel H110 SK1151 supports Intel Pentium CPU's, but I wasn't aware that I need to update BIOS. Is this something normal to do or by default is already ready and that warning is more like a heads-up?
Ryzen 1600 route:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (€198.99 @ Amazon Deutschland)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard (€96.20 @ Amazon Deutschland)
Memory: ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2800 Memory (€85.78 @ Amazon Deutschland)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€46.73 @ Amazon Deutschland)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB Mini Video Card (€264.90 @ Caseking)
Case: Fractal Design - Focus G ATX Mid Tower Case (€44.30 @ Amazon Deutschland)
Power Supply: Corsair - Vengeance...
Yes, you will need to update the bios to run the g4560. The only way to do it is to have a 6th gen Intel CPU. Maybe the board will be shipped with the right bios, but I would not bet on it.
Unfortunately the is not a Pentium with SMT in the 6th gen. You would have to get the i3 6100 for similar performance and it cost around 120.
You will need a board that says H270 or B250 to work without a bios update.
If you can buy it locally, you can ask the shop if they can provide BIOS update for you if needed. Otherwise, get B250 MB just to be safe:
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor ($78.89 @ B&H)
Motherboard: MSI - B250M PRO-VDH Micro ATX LGA1151 Motherboard ($64.99 @ Amazon)
Memory: Kingston - HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory ($117.95 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($49.56 @ OutletPC)
Video Card: Gigabyte - Radeon RX 560 2GB Gaming OC Video Card
Case: BitFenix - Nova ATX Mid Tower Case ($43.98 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($92.99 @ Best Buy)
Total: $448.36
Generated by PCPartPicker 2017-11-08 14:41 EST-0500
Thank you everyone I learned a lot. Honestly didn't knew about this BIOS stuff, in this case instead of the Pentium probably the best (if wallet allows it) is to going right for an iX or Pentium's are still an option to consider?
What is your budget? We can help you with the best parts for the money.
Right now I don't have a budget by default, but I'll accept your help and work it from there.
I'm looking for a decent PC, not to high-end or enthusiastic but something for like 5 years more or so. So I was thinking, instead of the G4560 it could be the i3-7100 or i5-7500 I don't plan to record or stream so I think an i7 is more than what I need . There's also the Ryzen CPU's but I'm not very inside into it, in fact I didn't knew the intel G4560 was nearly the same as an i3 so I discover it by an accident while reading this forum :wahoo:
Let's say ~800€ with possibility to stretch
Ryzen 1600 route:
Power Supply: Corsair - Vengeance 550W 80+ Bronze Certified Semi-Modular ATX Power Supply (€63.70 @ Amazon Deutschland)
Total: €800.60
Generated by PCPartPicker 2017-11-09 16:47 CET+0100
want to get 8400 build but it seems to be 30 euros more than 1600 atm and makes it hard to fit in.
