Help with cpu cooler, maybe others on my new build
Jarell420
78
Hellooooooo forums! As the title says, I am going to require some assistance from the "pros". This is my 2nd build and my 1st one went alright, but i feel this one will be more fierce. I plan on building a Micro ATX build that can support SLI. (I prefer the small sleek look). So here are my parts so far!
Fractal Design Define Mini!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352011
1TB WD for storage of my games.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
MSI 770 OC 2GB!
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127741
XION 850W Modular PSU!
http://www.newegg.com/Product/Product.aspx?Item=N82E16817190032
GeIL ddr3 1600 8gb (2 x 4gb) RAM!
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144614
AsRock Z87M Extreme 4!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157373
INTEL i5 4670k 3.4 ghz!
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
Samsung 840 EVO 120 GB SSD + Bracket!
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147247
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994085
So I'm still in the search of a CPU cooler and I was wondering if i should go with Liquid or Air cooling. The case also can handle two extra 120mm fans so I plan on buying 2 other ones also for the case.
MY BUDGET IS ~$1300
Great choices, heard good things about Phanteks. I have the R4 case too, its sweet.
Enjoy.
It's sold out on newegg 🙁 and im trying to order everything on one website. I have a 212 evo on my current build and it's alright, but i feel like they're are better ones out there now for either the same price or 5-15 dollars more.
Ive only heard good things about Noctua coolers especially if a quiet system is important. If you dont mind noise then go Liquid cooling depending on budget. If ur not overclocking then anything similar to the Evo is fine.
Links please.
This is the one and I believe it fits your case but double check
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608014
Quiet, efficient and durable. (6 yr warranty)
Ohh this one, I saw this on a youtube video and it was able to fit, but it was blocking the space for where a top fan could be placed. I might get that noctua, but as for the case do you think that fan space getting taken up by the cpu cooler is a good trade? I still would have another opening on the side of the case for another fan and im trying to reach maximum air flow with a budget because i plan on oc'ing my cpu, but mostly my gpu.
Links please.
Im either going to get an h80i or a noctua nhu-14s. The pros about the h80i is that it cools better than the noctua, but i hear a lot of people talk about the pump making weird noises after a few months of usage and i dont want that to happen. Im also changing my case to the CORSAIR OBSIDIAN 350D. Any suggestions?
If its not too late. \
I hate fan noise so I would go Noctua plus it has awesome durability. The difference performance wise could be argued as negligible.
Lol ive changed the case to an r4. The 770 to a 760. And i decide to get the phanteks tc14pe ^_^
Enjoy.
