Help with CPU GPU conflict
XFunc_CaRteR
14
Okay, it's an old system. Sorry.
I've had a problem for awhile. I seem to have a conflict between my CPU and my GPU trying to take control of my system's video.
When I play games they are often really dark. Then I come back to desktop and it's dark, I open up the advanced settings for my GPU, hit the colour and the picture pops back to normal brightness.
ATI 9600 Radeon
Intel 4 CPU
I get this message in the device manager too:
I/O Port 0x00000000-0x00000CF7 PCI bus
I/O Port 0x00000000-0x00000CF7 Direct memory access controller
I/O Port 0x000003C0-0x000003DF Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
I/O Port 0x000003C0-0x000003DF RADEON 9600 SERIES
IRQ 16 RADEON 9600 SERIES
IRQ 16 Standard Universal PCI to USB Host Controller
Memory Address 0xE0000000-0xF6FFFFFF Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Memory Address 0xE0000000-0xF6FFFFFF RADEON 9600 SERIES
IRQ 18 Standard Universal PCI to USB Host Controller
IRQ 18 Standard Dual Channel PCI IDE Controller
Memory Address 0xA0000-0xBFFFF PCI bus
Memory Address 0xA0000-0xBFFFF Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Memory Address 0xA0000-0xBFFFF RADEON 9600 SERIES
I/O Port 0x000003B0-0x000003BB Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
I/O Port 0x000003B0-0x000003BB RADEON 9600 SERIES
I/O Port 0x0000C000-0x0000CFFF Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
I/O Port 0x0000C000-0x0000CFFF RADEON 9600 SERIES
I checked up latest drivers for the Intel 82865G graphics controller: there are only two versions available: one is not supposed to be used with an external AGP GPU, and the other is only for developers. I tried the for-developers one anyway, but the automatic installer would not install it, and the manual install instructions required me to go to device manager and manually install over my Radeon driver, which I sure as hell am not gong to do.
Am I stuck with a CPU that hates my graphics card??????
Any help would be most appreciated. This is driving me nuts.
Your CPU won't be a conflicting with your GPU.
Like Vern mentioned, since theres a chance that you have integrated video, depending on the bios you need to be sure you have certain things disabled.
For example some integrated video will work with an AGP or PCI-E interfaced card. So you can run more then one monitor and have allot more desktop room.
Chances are, if your integrated video does not have the option to work with other cards, it should be automatically disabled from inserting the AGP card, but all MB vary to their settings.
The bright and darkness you describe would be more of the game and drivers having some kind of problem. Kinda sounds like the games your playing don't exit properly.
The only time I experience the desktop to be bright, (usually end up rebooting) is when the game crashes.
I have looked through the motherboard utilities to try to do this. The latest drivers only give RAID functionality, which has nothing to do with this. Also, I thought that since my monitor is hooked up to my GPU that it wouldn't matter as much.
Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
ASUS P4P800 Deluxe Motherboard
ATI 9600 Radeon GPU
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 5 GenuineIntel ~2798 Mhz
BIOS Version/Date American Megatrends Inc. 080009, 23/06/2004
SMBIOS Version 2.3
Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
I have looked long and hard for a way to disable the onboard graphics of my motherboard. Looked in the manual. Went through the BIOS. The only thing there seems to be is a setting in BIOS that lets you switch from AGP/PCI to PCI/AGP control. Whatever that does.
How do you disable onboard graphics for these things?
Well, if you are all saying there is no conflict what do I do?
I set my advanced settings for the ATI Card to play at max gamma and max brightness. Then I go into certain games and it's like midnight. I set the game's gamma to to absolutely brightest. Nothing.
Ur motherboard model don't have integrated graphic because i once use it long time ago (chipset 865PE)
If it doesn't have onboard graphics, how come it has a blue plug in the back to plug in a monitor?
Okay my bad.
I just stripped out all my ATI drivers to basically take that out of the question.
So now when I boot it goes into a default VGA mode that must be generated by the motherboard (P4P800 deluxe) and this VGA signal is really dark. I am trying to find out how to increase the brightness. So when I reinstall the ATI drivers I don't get this problem again.
I have a feeling if I get another vidcard, it won't matter - I'd need a whole new system. Somehow the damn thing is just set to be dark, and the get games the ATI driver and the default VGA driver confused somehow.
Does someone know how to adjust gamma on a default asus mboard vga driver?
Any help is greatly appreciated.
Your CPU wont conflict with your video driver, but from what it looks like you might have a conflict somewhere if your motherboard has an integrated video on it. What you need to do when you is list your entire system specs with a program like Everest Home Edition or PC Wizard 2007. Copy the overall system specs and then we can take a look.
The only suggestions I can give you right now are this. When your computer first starts up go into your BIOS and look for an area called chipset and try to disable the onboard video. If you cant find a chipset, look for anything that would resemble the video card settings on your video card. Afterwards what you should try to do is this. Uninstall your video card drivers, and follow the instructions of driver cleaner pro. You need to follow the exact instructions. And then install the latest video drivers for your ATI card and then go from there. I am running an nvidia card but when you install your ATI drivers under somewhere in the monitor there should be an option to adjust your brightness, contrast, Gamma etc. on somewhere in the catalyst control center. If you cant find it please let me know. Private message me more with details and I will see if I can help you out with your problem.
Done all that already. Right now I'm running the machine with no ATI drivers and it is very dark. The ATI card is sitting, doing nothing. I used a utility from ATI that removes all ATI software from the system. The motherboard is providing a VGA signal to the monitor and it is now very dark.
I can't be the ATI Card. It has to be the motherboard VGA.
When the ATI card kicks in it is fine - goes right to the brightness setting I put it at. But sometimes my system pops into a dark mode, and I think it is the motherboard's default VGA driver interferring. It's like the ATI card is fighting with the motherboard for control of the signal, and when I start a game sometimes the game I start decides it wants to listen to the ATI driver, sometimes it wants to listen to the mboard's VGA when it decides the gamma level of the game.
I am thinking about reinstalling the vga.drv and/or vga.dll files in windows, but I don't know exactly where to get those.
Went into the bios. There's nothing that lets you turn off your onboard video on the P4P800 Deluxe. All the drivers listed for the mboard have nothing to do with video or VGA. Maybe there is a generic, default ASUS vga driver but I can't find it.
Okay maybe this is overkill, but I provided my whole system info above, and people still kept telling me I needed to give my "exact system specs" so here is a dxdiag report...
System Information
Time of this report: 4/14/2007, 21:25:16
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
BIOS: BIOS Date: 06/23/04 15:29:16 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 336MB used, 3606MB available
Windows Dir: C:\WINDOWS
Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Current Mode: 1024 x 768 (32 bit) (1Hz)
Monitor:
Monitor Max Res:
Driver Name: vga.dll
Driver Version: 5.01.2600.0000 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 8/23/2001 07:00:00, 9344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: vga.sys
Mini VDD Date: 8/3/2004 23:07:08, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SoundMAX Digital Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_80F31043&REV_02
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: smwdm.sys
Driver Version: 5.12.0001.3630 (English)
WHQL Logo'd: Yes
Date and Size: 6/2/2003 13:42:14, 578304 bytes
Other Files:
Driver Provider: Analog Devices
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 48000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
Description: Modem #0 Line Playback (emulated)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
Description: Modem #0 Line Record (emulated)
Default Sound Capture: No
Default Voice Capture: No
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x20
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SoundMAX WDM MIDI [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/23/2001 07:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 23:14:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Lucent Win Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 171.7 GB
Total Space: 286.2 GB
File System: NTFS
Model: Maxtor 6L300R0
Drive: F:
Free Space: 2.4 GB
Total Space: 10.0 GB
File System: FAT32
Model: WDC WD800JB-00FSA0
Drive: G:
Free Space: 18.3 GB
Total Space: 56.5 GB
File System: NTFS
Drive: D:
Model: LITE-ON CD-RW SOHR-5239V
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:54, 49536 bytes
Drive: E:
Model: Memorex 52MAXX 3252AJ1
System Devices
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Device ID: PCI\VEN_8086&DEV_2571&SUBSYS_00000000&REV_02\3&267A616A&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/3/2004 23:07:42, 42368 bytes
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&267A616A&0&00
Driver: n/a
Name: Standard Universal PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_80A61043&REV_02\3&267A616A&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_80A61043&REV_02\3&267A616A&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:44, 7168 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_80A61043&REV_02\3&267A616A&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 07:00:00, 3328 bytes
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_80A61043&REV_02\3&267A616A&0&EA
Name: SoundMAX Integrated Digital Audio
Device ID: PCI\VEN_8086&DEV_24D5&SUBSYS_80F31043&REV_02\3&267A616A&0&FD
Driver: n/a
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_80A61043&REV_02\3&267A616A&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_80A61043&REV_02\3&267A616A&0&FB
Driver: n/a
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_80A61043&REV_02\3&267A616A&0&E8
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&267A616A&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 07:00:00, 35840 bytes
Name: Intel(R) 82801BA/CA PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&267A616A&0&F0
Driver: n/a
Name: Lucent Win Modem
Device ID: PCI\VEN_11C1&DEV_0440&SUBSYS_04401668&REV_01\4&2E98101C&0&48F0
Driver: n/a
Name: RAID Controller
Device ID: PCI\VEN_1106&DEV_3164&SUBSYS_80F41043&REV_06\4&2E98101C&0&20F0
Driver: n/a
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_808A1043&REV_46\4&2E98101C&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:58:30, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:58:30, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 08:46:40, 6400 bytes
Name: 3Com Gigabit LOM (3C940)
Device ID: PCI\VEN_10B7&DEV_1700&SUBSYS_80EB1043&REV_12\4&2E98101C&0&28F0
Driver: C:\WINDOWS\system32\DRIVERS\EL2K_XP.sys, 1.00.0000.0046 (English), 7/31/2003 04:53:28, 147456 bytes
Driver: C:\WINDOWS\system32\EL2K_CPP.dll, 1.00.0000.0005 (English), 4/23/2003 01:16:18, 61440 bytes
Name: Video Controller
Device ID: PCI\VEN_1002&DEV_4170&SUBSYS_00031002&REV_00\4&38B71F77&1&0108
Driver: n/a
Name: Video Controller (VGA Compatible)
Device ID: PCI\VEN_1002&DEV_4150&SUBSYS_00021002&REV_00\4&38B71F77&1&0008
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 07:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 00:56:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 00:56:46 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:26 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 00:56:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 12/20/2002 10:40:58 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 12/20/2002 10:40:58 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0003.0740
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Vorbis Decoder,0x00600000,1,1,OggDS.DLL,0.09.0009.0005
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0004.0020
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0020
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Vorbis Encoder,0x00200000,1,1,OggDS.DLL,0.09.0009.0005
Ogg Multiplexer,0x00400000,1,1,OggDS.DLL,0.09.0009.0005
Nero AAC Parser,0x00400000,1,1,NeAudio.ax,1.00.0004.0020
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0009
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0009
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0020
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.DLL,0.09.0009.0005
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Analog Devices Kernel wavetable Synth,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX Pro 5.0.3 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Sunplus 32-bit Compressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
SoundMAX Digital Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Modem #0 Line Record,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
SoundMAX WDM MIDI,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
SoundMAX Digital Audio,0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SoundMAX Digital Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Modem #0 Line Playback (emulated),0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: SoundMAX Digital Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
Modem #0 Line Playback,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
SoundMAX Digital Audio,0x00200000,17,2,,5.03.2600.2180
Yeah... That's overkill. You said the have an "Intel 4" Im assuming you meant a P4, what speed? And an ATI 9600, is that an actual 9600, or one of the many different variations, SE, XT, Pro, ect?
optical drive: LITE-ON CD-RW SOHR-5239V
optical drive 2: Memorex 52MAXX 3252AJ1
mobo: Asus P4P800 Deluxe
We still need the make model of your psu and ram.
Phew..... :roll:
Ah full system specs means:
CPU
Video card
Motherboard
Power Supply
Case (if its a temperature/cooling issue)
Sound Card (if its a sound issue)
RAM
CD/DVD rom drives (not usually required)
Dont need all the junk dxdiag spits out lol. Just whats listed above, including model numbers etc.
I'm not very familiar with that motherboard, but your best bet is just to start from scratch. Remove any/all drivers that you installed yourself. Ranging from the Motherboard drivers, sound drivers, video drivers, CPU drivers, etc etc. (Try not to format the hard drive but remove all the drivers and follow the driver cleaner pro instructions if possible.)
Afterwards what I would suggest is try to work your way from the ground up and then go from there. I'll see if I can do more digging and try to help you out. There just seem to be some inconstancies in your posts and I'm spending more time trying to get together an idea of what is going on. But I will do whatever I can to help you out man.
Edit: Well I read your post some more and I will try to list the best places to get your drivers. All in all my rundown is this. remove every and all drivers from your computer. Go from the ground up and then reinstall each individual driver. Then go from there, that is what I would do. There is so much technical whatnot and so much bs going on that it's difficult to try and wade through all this but I am going to try and dig to the core of your problem
1. For your ATI drivers go here
2. For your Intel 82856G Drivers go here
3. Support Site for Your SoundMAX Audio Drivers
4. (If Necessary Update) Direct X9.0C April 2007 Release
5. (Everest Home Edition) Program That Can Get You Your System Info
6.PC Wizard 2007
Yah, I did a scan with Driver Detective and there are a bunch of missing drivers. So I think I will just leave it at that for now - get those drivers upgraded somehow.
Is that a good program, Driver Detective? It seems a lot easier to use it than to try to sift through all these sites getting these things. It seems about half my drivers are out of date, but some I have no idea how to update. Tried updating my Intel 865E, downloaded a program that would do it but it wouldn't work.
The vidcard is a bonafide ATI Radeon 9600, simple as that, from what I can tell. I've looked at device manager and that's what it says.
I don't think this is my ram. I replaced all my ram about 6 months ago, but still had the same problem.
Couldn't tell you what my cpu is exactly.
I fixed the problem with running the game. It has an open that lets you run it in a window, so I do that, and that way my Radeon has guaranteed control over the appearance settings.
Thanks for looking over this.
Ok man, if you want to do something right, do it one step at a time. That is the only way your going to actually get the computer working. I gave you the tools, but unless you want to put in the footwork your problem wont be fixed.
Well, I already did strip away all my graphics drivers - that I could find at least. I mean there has to be some drivers left, otherwise you wouldn't be able to see anything.
And I ran it in Safe Mode, and in Safe Mode it loaded this VGA driver, and sure enough, the screen is dark with it. So, like, I figure this problem is at the default-video-driver level.
So, again, I looked on the ASUS website, and they have nothing for the P4P800 Deluxe mboard that is about video drivers. So maybe they have a generic vga driver somewhere that isupdated.
I already updated bios recently, too. No change in the issue.
I know that the Intel CPU driver probably needs updating. Maybe you could point me to somewhere that tells how to do that. I tried going to Intel, to no avail. They have a utility that is supposed to tell you what chip you have - but it didn't run on my machine (was corrupted or something). I re-downloaded it - no difference.
Can you tell me to find out what exact CPU I have? All I know is it's Intel 82865G/PE/P/GV/82848P Processor series.
Thanks again.
Hi guys! I'm going to build a PC and I was wondering if there will be conflict between Intel Pentium G840 and PowerColor HD 6870 or do I have to look for different GPU? Thanks! 😉
