Question help with CTR - Clocktuner for Ryzen 3600
Hi i want to overclock my pc for gain in gaming performance in csgo.
Below is the result after i run the test, now what should i interpret the results and how to overclock with the software? thanks
View: https://i.imgur.com/z7bjcsM.jpeg
CPR is not an overclocking program but for optimizing voltages and power. That may result in better performance if your BIOS settings are way offa nd you often run into temperature barrier. It uses Ryzen Master to enact settings.
It's best to OC in the BIOS itself but if you insist on software OC you can use RM auto OC option.
PS. What CPU cooler ? With OEM cooler you may not get far.
