Help with custom-built PC for GAMING & ART PROGRAMS
Oct 28, 2017
9
Greetings everyone, I'm in the search for the right components to build my first computer and I truly have no idea of how to build a computer from scratch so i need all the help i can get. I'll be using the computer firstly for Adobe & Autodesk programs and similar applications, and then for Gaming (games that are graphically demanding. EG: Destiny2)
I have a $2100 dollars (Including peripherals) top budget but i think a little bit can be added to it.
P.S. I live in Australia (Difference between the value of currencies)
All the help will be very appreciate :)
For a white-ish build, i'd go with this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($275.00 @ Shopping Express)
Motherboard: MSI - B350M MORTAR ARCTIC Micro ATX AM4 Motherboard ($128.00 @ Shopping Express)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory ($249.00 @ Scorptec)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive ($209.00 @ Centre Com)
Storage: Western Digital - BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($165.00 @ Shopping Express)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card ($369.00 @ Umart)
Case: NZXT - S340 (White) ATX Mid Tower Case ($101.20 @ Skycomp Technology)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply ($119.90 @ Newegg Australia)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($124.00 @ Shopping Express)
Monitor: Dell - U2417H 24.0" 1920x1080 60Hz Monitor ($335.00 @ Shopping Express)
Total: $2075.10
Generated by PCPartPicker 2017-11-01 04:17 AEDT+1100
If you don't need an OS that would cut costs.
Peripherals IMHO are very opinion based so i can't pick them for you.
For a cheaper build you could not match colors, etc. But all parts there are great as well, just wanted to make a themed build.
Cheers!
