Question Help with driver downloads
Nov 26, 2019
18
Hi guys, i needed help knowing what motherboard drivers to install for an asrock fatal1ty b450 gaming k4.
Do i download all of them?
I personally make a folder for my MB drivers and download ALL the drivers and Utilities they have available.
BUT I Only install the drivers and utilities that I will actually use.
I would definitely Install these:
  • AMD all in 1 with VGA driver ver:19.10.16_19H1_WHQL
  • Realtek high definition audio driver ver:8619_UAD_WHQL_Creative
  • Realtek Lan driver ver:10023
And the AMD chipset drivers (install these last):
https://www.amd.com/en/support/chipsets/amd-socket-am4/b450
The other drivers and utilities are only necessary if you actually will use them.
For example there is no reason to install the AMD RAIDXpert2 utility unless you are going to set up a RIAD array.
I downloaded all of them but the audio driver wont download it says the driver does not support my system.
