Help with entire 5.1 setup.
Cvdasf
526
I have a 5.2 denon AVR- S500BT that used to run the KLF 10 speakers, beta c360 center, RF2 II speakers, and the sub in a much larger room. I have sense moved to a 12 by 12 room which feels pretty tight with that setup still.
I have sense taken two B&W DM 600 s3's and want to replace either the RF3 II or KLF 10's. Which speaker would be better to replace? Or should I keep what i had and find a way to fit them in? Would It be an upgrade or downgrade to replace the RF3 II's/KLF 10speakers?
As far as placement goes in the room...I currently have KLF 10 speakers, B&W DM 600 s3's and a infinity beta c360 center. The sub im running is a model f-12 12" BIC sub. I have a Denon AVR s500BT receiever running it all.
Heres my room..
are the speakers in correct positions? Is there a better way to place them? I sit in the black chair at the desk with three monitors. Thanks :)
