[SOLVED] Help with first build
Dec 26, 2018
I have a question, I just got this case(cooler master h500) but is there any way to control the two 200mm fans with a motherboard or through a software. My motherboard is a asus prime z390-a. I also bought a cooler master ml240r liquid cooler which also has a controller. Can I plug in the 200mm fan controller to the other one
Thanks in advance
That motherboard has a thing called "fan expert', take a look at that https://www.asus.com/Motherboards/PRIME-Z390-A/
The RGB controller with that Cooler Master cooler has connections on it for "compatible devices", you can check with them if those fans are "compatible devices".
