Hi, this is my first time building a computer and im looking to build a mini itx.
i tried to research and choose the components but i just wanted to make sure the hardware fits the case and if psu is enough and if the build is okay with overclocking.
here is the build:
CPU- intel Core i5-3570K 3.40GHz (Ivybridge)
Motherboard- Asus P8Z77-I Deluxe
Case- Silverstone FT03 mini
GPU- Galaxy GTX 670 ( i chose this because i think it will fit the case, however im unsure that the psu would handle it)
SSD-Samsung 250GB SSD 840 SATA
HDD- Western Digital Caviar Black 1TB SATA
PSU- Silverstone Strider SFX Gold 450w '80 Plus Gold' Modular Power Supply
RAM- Corsair Vengeance Blue 8GB (2x4GB)
ODD- Silverstone SST-SOD02 Slimline Slot Loading 8x DVD±RW SATA Drive
Cooling - Corsair H60 Performance Intel Liquid Cooling Solution (do i need an extra fan or mounting the rad on the bottom of the case is enough, also thermal paint is needed for any kind of heatsink right ?)
OS- Microsoft Windows 8 64bit
any advice or modifications would be helpful thanks
here is the build:
