Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
To start with I am not exactly inexperienced as I have built four PC's
using Asus boards, but I have only ever fitted two hard drives and have
never entered the realms of learning about SCCI or Raid whatever. I am
OK with fitting simple IDE hard drives and that is where my experience
ends.
I needed a third drive on my A7V8X so bought a PCI controller card (non
raid version) fitted that with its software and XP recognises it.
I tried to run my current two hard drives off its primary connection and
they would get recognised on boot up.
I put them both back direct off the motherboard and put the new drive
(as master) running off the new controller card and that works OK and I
can use the third drive.
Is that the way it should be? I thought all three might run off the new
controller?
The other strange thing (to me at least) was that when I used IBM set up
disk, it recognised the new hard drive (running off the controller) as a
SCCI drive - is that right?
XP then formatted it OK and it works, so I suppose everything is OK.
The only strange thing is that if I check "My Computer" all the disks
display after a while (the serhlight comes on which it never used to),
and if I try to change the drive (to write to) in another programme, it
takes about 30 seconds to display all the drives available - which seems
a very long time?
Any input greatly received, hope this is the right group to ask in?
Regards,
Peter
ends.
controller?
a very long time?
Regards,
Peter
