Help with fitting cooler Master hyper 103
Jake_96
44
Hi, I have a cooler Master hyper 103 on order and my motherboard is gigabyte ga-f2a78m with kavari 7850k.
I have never fitted a cpu cooler before so any tips would be great, in particular the use of thermal compound scares me a little as I have read conflicting views on the correct amount to use.
Thanks in advance!
the purpose of thermal paste is to eliminate air between CPU and cooler surfaces. a pea size drop should be enough for most case. I don't think methods of applying make big different.
The installation is quite straight forward, watch some videos before install if you like.
Thanks guys I don't know what I was worried about, installed it fine and now whilst gaming my thermal margin sits between 40-55 under heavy load, and it's pretty quiet.
