Help with flight sim rig I7-4960X / MSI X79A-GD45(8D)(MS-7760) ONLY 4600 MHZ?
voodoovoodoo
5
Hi, I just built an I7-4960X 3.6mhz and when overclocking, the system runs FSX like a champ OC'd to 4600mhz but if I try to run it at 4700, I cant get past the bios setup screen. I have updated the bios and my temps seem fine. I have lowered the voltage but cant seem to run over 4600 under any circumstances.
You guys are the experts here. Help a guy out! :)
Thanks in advance!
W
OK, I ran it up to 1.345v and was able to achieve 4700mhz.
Tried 1.345v and 1.35v but couldnt get 4800.
Ideas?
OK, I'll try that thank you.
On the Ram side, I am running 4 4gb corsair vengance 1600mhz ddr3. Is it faster to run 4 32gb for better cooling or otherwise? Will this MOBO support 1 stick of ram?
Oh, I see. Thanks
On the Ram. What do you think?
